jthompson55
Apr 15, 2022Follower
CM1100 Upstream light red
Upstream light is solid red. What do I need to do to turn it green.
- Apr 15, 2022
Post a screensnip of the cable connections page and the event logs. Those help us more than just that you have a red light.
It usually indicates a line issue though.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
Apr 15, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
RED or AMBER? https://www.downloads.netgear.com/files/GDC/CM1100/CM1100_UM_EN.pdf
• Solid amber. One upstream channel is locked.
• Solid green. Two or more upstream channels are locked.
• Blinking green. The cable modem is scanning for an upstream channel.
• Off. No upstream channel is locked
