Ghost1257
Mar 25, 2022Guide
CM1100 Warnings and errors.
here is my log 2022-03-25, 08:12:00 Warning (5) Dynamic Range Window violation 2022-03-25, 08:12:00 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of t...
- Mar 27, 2022
Thanks I took a device off that they wanted on there and have not had any more errors.
Mar 25, 2022Guru - Experienced User
your log indicates line issues.
Your cable connections page helps as well if you screensnip that.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
