aaronmcd1214
Feb 04, 2020Tutor
CM1100 will not accept more than one device
Trying to get my new modem setup and it appears that only 1 LAN port will provide internet access at a time. Called Cox to activate the modem and plugged my PC into it directly to test and everything...
- Feb 04, 2020
No, its just a bad explaination by Cox and Netgear.
the dual port on the cm1100 is designed for port aggregation (which most routers don't have) or for ISP's that allow multiple public IP addresses (most don't). I know comcast and cox don't allow it free. You can pay extra or get a business line that allows it but the standard setup doesn't.
So for the average user, the 2nd port is useless.
Try shutting off both the modem and router and disconnecting everything from the modem.
Power the modem back on and give it a few minutes.
then connect port 1 of modem to the wan port on the orbi.
The power up the orbi. Give it a few minutes and then try going through setup.
Feb 04, 2020Guru - Experienced User
aaronmcd1214
Feb 04, 2020Tutor
Thanks for clarifying. My previous setup was with an Arris Surfboard combo unit that had 4 ports on the back and every device plugged into it worked. I'm assuming those were different then?
- plemansFeb 04, 2020Guru - Experienced User
It was problem a modem/router combo device.
the CM1100 doesn't have an integrated router. Its a modem only device.
- plemansFeb 04, 2020Guru - Experienced UserMean to say probably, not problem.
- aaronmcd1214Feb 04, 2020TutorGot it. Thanks for helping me understand!
- FURRYe38Feb 05, 2020Guru - Experienced User
The CM1100 is just a modem, not built in router.
You can connect two external routers behind the CM1100 though. It works. :smileywink:
