Xerloq
Jan 13, 2026Aspirant
CM1100 won't connect to routers
I have a CM1100 that started having issues today. It will not connect to my router. It will, however, connect directly to a laptop. My setup is: ISP -> CM1100 -> Router/Firewall -> APs & Swit...
Xerloq
I use a Firewalla Gold SE. I used a Linksys MX4300 for troubleshooting. It cannot connect to the CM100 either.
I am not using port agregation
Astound Broadband
I have tried both LAN ports multiple times with multiple cables.
The CM1100 was power cycled multiple times for 30+ seconds. I've done that with and without the router connected
I don't think it's an issue with the router as it can connect through the cellular modem.
For clarity, neither the Firewalla Gold nor the MX4300 work with the CM1100. Both work with the cellular modem. A laptop connected directly to the CM1100 works.
- FURRYe38Jan 14, 2026Guru - Experienced User
Try a 30-30-30 reset on the modem and see. If this fails, ya, guess modem has gone bad.
