Luu5hahc
May 04, 2019Aspirant
CM1100 won't do IPv6 with Cisco router (on Xfinity)
Cisco 2851 router with IOS 15.1(4)M12a
SB6141 has been running for years doing IPv4 & IPv6, with /60 PD, and no problems.
I bought a new CM1100 (fw 2.01.02), plugged a Macbook directly into i...
Luu5hahc
May 05, 2019Aspirant
I went back and reviewed the Wireshark packet captures I had made, both on the standalone Mac, and on the vlan capture made via running the CM<->router traffic running through a monitored VLAN on a switch. It finally occurred to me that the router sends out IPv6 routing advertisements, (expected of any IPv6-capable router), but the Mac does not (as expected of a standalone host).
Some research of Cisco docs pulled up these interface options:
ipv6 nd ra suppress (to suppress unsolicited RAs)
ipv6 nd ra suppress all (to suppress all RAs)
I suspected the RAs on the interface toward the modem were not needed in this topology, so I added the "ipv6 nd ra suppress" to the interface, then power-cycled the SB6141. Everything worked as normal. (Solicited RAs are still available if requested.)
Then I crossed my fingers, swapped in the CM1100, and registered with the Walled Garden.
It works. So the problem is a bug in the firmware of the CM1100 that causes TFTP failures if RAs are seen on the LAN interface, but at least there is a workaround.
- vkdeltaMay 06, 2019NETGEAR Employee Retired
as far as I know, you should not send any RAs on the Cisco's WAN interface (behind Cable Modem).
RA's are needed on the LAN side and not on WAN side.
