trw117
Oct 08, 2020Aspirant
CM1150 - ethernet ports on the back
Should all 4 ports work on the back of the modem? When I spoke to technical support at Netgear they said only one would work at a time. When I spoke to Comcast, they said all 4 should work. Who is...
Oct 09, 2020Guru - Experienced User
- trw117Oct 09, 2020Aspirant
Thank you, you were veryhelpful!!
Only one port will work. It's really not abig deal for me since the wi-fi node has two on the back of it.
I appreciate the reply! Have a great week!
- FURRYe38Oct 09, 2020Guru - Experienced User
If you need additional ethernet ports, you can install a non managed ethernet switch for additional ports, they make them from 5 to 48 ports units.
Good Luck.
- char8baOct 18, 2020Aspirant
does anyone know where to get the info. for the other three port for aplication and configuration can not find on netgear sight ???
