jmg001
Jun 29, 2022Aspirant
CM1150 critical errors requiring reboot
I've been using a CM1150V modem with Xfinity for about 18 months w/o issues (replaced an old Arris when it failed). When issues occur (randomly, several time per day) I'll initially noticed internet...
jmg001
Thanks for the quick response. Unfortunately, since I needed to activate the rented XB7 Gateway from Xfinity temporarily in order to work from home effectively, I can't provide new or updated logs from the CM1150V at the moment (I may be able to reactivate it and monitor things further over the weekend).
My real question is this - is it possible that the XB7 handles signal and line issues more "forgivingly" than CM1150V since, with the exact same setup other than the modem swapout, I don't seem to be encountering the same issues?
Thanks again!
Jeff
Jun 29, 2022Guru - Experienced User
Anything is possible. However hard to tell anything with out seeing event and cable connection status logs.
- jmg001Jul 07, 2022Aspirant
The Xfinity XB7 gateway has continued to run w/o issue. I'm going to chalk this up to my Netgear having failed (and submit an extended warranty claim to Amex). I've ordered a replacement modem, and we'll see if the issue return with that and evaluate things further at that time. Thanks again...
- FURRYe38Jul 07, 2022Guru - Experienced User
Hard to tell anything with out seeing event and cable connection status logs. Not having this would not be a cause for marking this as a solution.
