jimohare
Feb 22, 2025Aspirant
cm1150 issue with emta event log causing modem to reboot
I find it hard to believe that Netgear still has yet to admit their cm1150 devices all reboot when a user simply tries to view the emta event log under advanced. I can reproduce this on demand since...
Feb 22, 2025Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
- jimohareFeb 26, 2025Aspirant
been a CCNP for 25 years and have a cat 8 cable connected.
There is no doubt that the device has a bug and there is not newer firmware since I first discovered the issue.
as soon as you navigate to Advanced
Administration
then click on the link for
EMTA Event Log
the device simply reboots!
I was simply asking if any other NETGEAR users with the same model device can confirm this happens when they do the same?
Typically Xfinity will update this device when you rent it but i bought mine so I feel like Netgear owes me an explanation as to how they never tested the links on their product?
I am about to stop using netgear because of the router i bought my son r10000
I use the r9000 for my home and thats connected to the cm1150 and while i liked that router enough to buy it for my other homes it seems to get wiped and i am starting to think hackers are somehow getting into it and factory resetting it...but thats not this post...i am sim0ply ticked that years after i discovered this flaw in the cm1150 i see another post that netgear knows about it back then and then no more replies!
why is this not fixed yet?
the device can be up for months and then as soon as you click on the link for the emta event log it reboots!
I would bet a million dollars on it so thats how sure i am it is not anything in my setup or environment or cables or the power supply or well you get my drift.
DOCSIS® 3.1 Cable Modem (CM1150V)
would like netgear to tell me if they know about this and if they intend to fix it.
- FURRYe38Feb 27, 2025Guru - Experienced User
Lets try something, disconnect the external router and ISP signal coax line from the CM modem. Press the reset button for 15 seconds then release. With one ethernet connected PC to the back of the CM modem, give 2 minutes then log into the modems web page at 192.168.100.1. Try the Event Log selection. Does the modem reboot here or does it display something?
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure
Procedure Status Comment Acquire Downstream Channel 495000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 20 495000000 Hz -2.6 dBmV 43.2 dB 0 0 2 Locked QAM256 4 399000000 Hz -1.8 dBmV 43.8 dB 0 0 3 Locked QAM256 5 405000000 Hz -1.9 dBmV 43.6 dB 0 0 4 Locked QAM256 6 411000000 Hz -1.8 dBmV 43.7 dB 0 0 5 Locked QAM256 7 417000000 Hz -1.7 dBmV 43.6 dB 0 0 6 Locked QAM256 8 423000000 Hz -1.7 dBmV 43.7 dB 0 0 7 Locked QAM256 9 429000000 Hz -1.6 dBmV 43.8 dB 0 0 8 Locked QAM256 10 435000000 Hz -1.4 dBmV 43.8 dB 0 0 9 Locked QAM256 11 441000000 Hz -1.7 dBmV 43.7 dB 0 0 10 Locked QAM256 12 447000000 Hz -2 dBmV 43.5 dB 0 0 11 Locked QAM256 13 453000000 Hz -2.2 dBmV 43.5 dB 0 0 12 Locked QAM256 14 459000000 Hz -3.1 dBmV 43 dB 0 0 13 Locked QAM256 15 465000000 Hz -3.8 dBmV 42.6 dB 0 0 14 Locked QAM256 16 471000000 Hz -3.8 dBmV 42.6 dB 0 0 15 Locked QAM256 17 477000000 Hz -3.2 dBmV 42.8 dB 0 0 16 Locked QAM256 18 483000000 Hz -2.8 dBmV 43.1 dB 0 0 17 Locked QAM256 19 489000000 Hz -2.5 dBmV 43.1 dB 0 0 18 Locked QAM256 21 507000000 Hz -2.8 dBmV 42.9 dB 0 0 19 Locked QAM256 22 513000000 Hz -2.6 dBmV 43.1 dB 0 0 20 Locked QAM256 23 519000000 Hz -2.6 dBmV 43 dB 0 0 21 Locked QAM256 24 525000000 Hz -2.2 dBmV 43.3 dB 0 0 22 Locked QAM256 25 531000000 Hz -2 dBmV 43.3 dB 0 0 23 Locked QAM256 26 537000000 Hz -2.5 dBmV 43 dB 0 0 24 Locked QAM256 27 543000000 Hz -2.9 dBmV 42.8 dB 0 0 25 Locked QAM256 28 549000000 Hz -3 dBmV 42.8 dB 0 0 26 Locked QAM256 29 555000000 Hz -2.8 dBmV 42.7 dB 0 0 27 Locked QAM256 30 561000000 Hz -2.8 dBmV 42.6 dB 0 0 28 Locked QAM256 31 567000000 Hz -2.5 dBmV 42.9 dB 0 0 29 Locked QAM256 32 573000000 Hz -2.3 dBmV 42.5 dB 0 0 30 Locked QAM256 33 579000000 Hz -2.6 dBmV 42.5 dB 0 0 31 Locked QAM256 34 585000000 Hz -2.8 dBmV 42.6 dB 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 2560 Ksym/sec 10400000 Hz 46.3 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 16400000 Hz 46.3 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 22800000 Hz 46.3 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 29200000 Hz 46.5 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Downstream OFDM Channels
Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 0 ,1 ,2 ,3 48 722000000 Hz -3.0 dBmV 41.5 dB 928 ~ 3167 10230194037 10094033588 6314 2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV
