billnh's avatar
billnh
Follower
Dec 23, 2019
CM1150V - NETGEAR01 SSID
I installed the CM1150V Cable modem about a month ago.  I noticed that there is another network with an SSID of NETGEAR01.  It's the same strength as my Router's SSID.  When I try to connect to it, it doesn't take the default password or the one I changed the admin of the CM1150V modem.  Any idea of what the password could be or how I disable this network?
1 Reply
  • plemans's avatar
    Whats your router?
    the CM1150V is a modem with voice. It doesn't have wireless built in.
    so whatever you're running for a router is likely to be that. Maybe its a dual band? Or did you put the wrong modem model?
