djkid1985
Jun 05, 2020Initiate
CM1150V - Slow speeds on Xfinity
I purchased a CM1150V modem to use with Xfinity Gig Internet. However, I'm not getting anywhere close to the right speeds. I have done troubleshooting with Xfinity: Reset modem physically using th...
Jun 06, 2020Guru - Experienced User
So do you get near 900Mpbs with a wired PC directly connected to the CM modem?
What PC are you using for speed testing?
djkid1985
Jun 06, 2020Initiate
I have never gotten more than 300Mbps directly wired to the modem. I have tried both a Lenovo and a Dell laptop, as well as an iMac.
I get the same speeds wired to the Netgear router, as well.
- FURRYe38Jun 07, 2020Guru - Experienced User
What are the model# of these PCs?
How old are these PCs?
