smgillespie28
Aug 05, 2022Aspirant
CM1150V and AC1600 connection problems
Been using an AC1600 with wifi disabled as a wired router for my CM1150V for a while now with no troubles. Big storm last night (yes, plenty of surge protection). When power came back on, the AC...
smgillespie28
AC1600 isn't a model number of a router.
It's the name, not the model number. Model number is R6260
In house cabling and coax is the same that's been working well for several years.
Be sure to power OFF the modem for 1 minute then back ON.
Did that but will do it again.
Please post a copy and paste of the modems connection status page.
Is this what you're looking for?
Aug 05, 2022Guru - Experienced User
Select the Cable Connection button you see on the modems web page. Copy and paste what you see on that page here.
- smgillespie28Aug 05, 2022AspirantCable Connection
Starting Frequency: 0Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency
Startup ProcedureProcedure Status Comment Acquire Downstream Channel 651000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4)
Downstream Bonded ChannelsChannel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 37 651000000 Hz -6.7 dBmV 39.6 dB 12 0 2 Locked QAM256 13 507000000 Hz -3.3 dBmV 41.3 dB 8 0 3 Locked QAM256 14 513000000 Hz -3.3 dBmV 41.4 dB 3 0 4 Locked QAM256 15 519000000 Hz -3.6 dBmV 41.3 dB 2 0 5 Locked QAM256 16 525000000 Hz -3.8 dBmV 41.2 dB 7 0 6 Locked QAM256 17 531000000 Hz -4 dBmV 41.1 dB 2 0 7 Locked QAM256 18 537000000 Hz -4.3 dBmV 41 dB 2 0 8 Locked QAM256 19 543000000 Hz -4.5 dBmV 41 dB 7 0 9 Locked QAM256 20 549000000 Hz -4.8 dBmV 40.8 dB 4 0 10 Locked QAM256 21 555000000 Hz -5 dBmV 40.6 dB 3 0 11 Locked QAM256 22 561000000 Hz -5.2 dBmV 40.6 dB 7 0 12 Locked QAM256 23 567000000 Hz -5.6 dBmV 40.3 dB 6 0 13 Locked QAM256 24 573000000 Hz -6 dBmV 40.1 dB 10 0 14 Locked QAM256 25 579000000 Hz -5.7 dBmV 40.3 dB 6 0 15 Locked QAM256 26 585000000 Hz -5.2 dBmV 40.4 dB 9 0 16 Locked QAM256 27 591000000 Hz -5.1 dBmV 40.5 dB 5 0 17 Locked QAM256 28 597000000 Hz -5 dBmV 40.5 dB 7 0 18 Locked QAM256 29 603000000 Hz -5 dBmV 40.5 dB 9 0 19 Locked QAM256 30 609000000 Hz -5.3 dBmV 40.4 dB 5 0 20 Locked QAM256 31 615000000 Hz -5.5 dBmV 40.2 dB 10 0 21 Locked QAM256 32 621000000 Hz -5.7 dBmV 40.1 dB 6 0 22 Locked QAM256 33 627000000 Hz -5.9 dBmV 40 dB 7 0 23 Locked QAM256 34 633000000 Hz -6.1 dBmV 40 dB 13 0 24 Locked QAM256 35 639000000 Hz -6.3 dBmV 39.7 dB 6 0 25 Locked QAM256 36 645000000 Hz -6.6 dBmV 39.6 dB 13 0 26 Locked QAM256 38 657000000 Hz -6.8 dBmV 39.6 dB 11 0 27 Locked QAM256 39 663000000 Hz -6.6 dBmV 39.7 dB 12 0 28 Locked QAM256 40 669000000 Hz -6.5 dBmV 39.8 dB 11 0 29 Locked QAM256 41 675000000 Hz -6.6 dBmV 38.5 dB 17 0 30 Locked QAM256 42 681000000 Hz -6.5 dBmV 39.8 dB 19 0 31 Locked QAM256 43 687000000 Hz -6.5 dBmV 39.7 dB 11 0 32 Locked QAM256 44 693000000 Hz -6.6 dBmV 39.6 dB 18 0
Upstream Bonded ChannelsChannel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 2 5120 Ksym/sec 16400000 Hz 38.5 dBmV 2 Locked ATDMA 3 5120 Ksym/sec 22800000 Hz 39 dBmV 3 Locked ATDMA 4 5120 Ksym/sec 29200000 Hz 39.5 dBmV 4 Locked ATDMA 5 5120 Ksym/sec 35600000 Hz 40 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
Downstream OFDM ChannelsChannel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 0 ,1 ,2 ,3 159 702000000 Hz -5.9 dBmV 39.3 dB 1126 ~ 2969 120536736 20747665 0 2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0
Upstream OFDMA ChannelsChannel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV
Current System Time:Fri Aug 05 16:02:37 2022
System Up Time:01:02:13 - smgillespie28Aug 06, 2022Aspirant
So one basic question is - for devices plugged into the CM1150V e-net ports - does the modem act at the DHCP server or is that managed upstream somewhere controlled by xfinity? That's my guess as to where things are failing.
- KitsapAug 06, 2022Master
You should have only one Ethernet connection to your CM1050V and that is your router. Your router provides DHCP services for the devices connected to your LAN. That includes both via Wi-Fi and Ethernet connections. Your router should be configured to enable "Use Router as DHCP Server."
Yes I know that's how it should work and that the modem only supports one device connected directly. But the router is not getting connected when it's that one device. While the computer when attached directly to the modem is connecting fine. Which brings me back to the last question. Where is the router supposed to get it's IP address from when it's the one device connected to the modem. From the modem - or somewhere further upstream?
If memory serves, I don't think this is new (the router not getting an IP address through some upstream DHCP server). I think I previously had the router setup to use a static IP address as a work around. Xfinity doesn't really support static IP addresses so maybe something about the storm made the old static ip invalid.
