tgary
May 04, 2020Aspirant
CM1150V and AX6000 RBR850 internet connectivity issues with Xfinity
So frustrated with my new equipment and internet! Can anyone help? Dumped ATT, got Gig internet with Xfinity, and a CM1150V (for voip) with Orbi AX6000 RBR850 and RBS850 Satellite. Worked great for...
tgary
Not clear if the screen paste captured the uncorrectables on the OFDM downstream, but in a little under two hours up, it was 13561874 correctable, and 5017 uncorrectable.
- FURRYe38May 04, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.- tgaryMay 04, 2020Aspirant
FURRYe38 wrote:Have the ISP check the signal and line quality UP to the modem.
Be sure your using good quality RG6 coax cable up to the modem.Hi, and thank you. They did. The Xfinity tech checked the line from tap to modem, and said it was very strong. (There is a single splitter to pull off the TV line.) I figured my lines would be the first thing Xfinity would blame if they could.
I'd pull the splitter off and directly connect the modem to the line and see if the problem still happens.
Also run some speed tests while the modem is connected with out the splitter and with a PC directly connected to the modem with out the RBR online.
