kingtj
Feb 03, 2019Star
CM1150V and Comcast - can't get gigabit speeds?
I just upgaded my Comcast Xfinity "Blast" Internet speeds to Gigabit, which required I upgrde my DOCSIS 3.0 Motorola cable modem. I ordered Comcast voice service too, with this upgrade, so apparentl...
love2scuba
Apr 27, 2019Aspirant
I had gigabite speed when I first installed the CM1150V modem. When I hooked up my AC1750 router the speed almost went to zero if I use the port on the modem. If I move it over to the router it is in the mid 500's along with the wireless speeds. Current firmware on the router:
V1.0.3.66_10.0.50
Any thoughts??
Apr 29, 2019Guru - Experienced User
I would post about this in the router appropriate forum.
If your getting speeds with out the router at the cable modem, then the router needs to be look at.
V1.0.3.66_10.0.50
Any thoughts??
