kingtj
Feb 03, 2019Star
CM1150V and Comcast - can't get gigabit speeds?
I just upgaded my Comcast Xfinity "Blast" Internet speeds to Gigabit, which required I upgrde my DOCSIS 3.0 Motorola cable modem. I ordered Comcast voice service too, with this upgrade, so apparentl...
CoolioBeans
Oct 01, 2019Aspirant
After some INTENSE expiditions through the internet I fell upon this reddit post:
A guy reccomends pushing in the the ethernet cable gauranteeing a perfect fit, because anything above 100Mbps needs all 4 ethernet contacts connected if it detects any less it will default to less than 100Mbps. I thought this was crap so I tried and it worked!!! getting 200+Mbps on my 175Mbps plan. :mansurprised:
PLEASE SHARE THIS ON ALL OF THE FORUMS YOU'VE CHECKED ALREADY!! I WILL DO THE SAME!
- antinodeOct 01, 2019Guru
> [...] pushing in the the ethernet cable gauranteeing a perfect fit,
> [...]If the cables/connectors are good, then you shouldn't need to do
anything special to get a proper connection. "Click" should be all you
need.> [...] anything above 100Mbps needs all 4 ethernet contacts connected
> [...]Anything above 100Mb/s needs all _eight_ conductors.
In any case, this is why Ethernet connectors frequently have
associated LED indicators. Visit http://netgear.com/support , put in
your model number, and look for Documentation. Get the User Manual.
Look for the LED descriptions. For example, in the CM1150V User Manusl
(page 8):
o Green. A powered-on device is connected to the Ethernet port
at 1000 Mbps.o Amber. A powered-on device is connected to the Ethernet port
at 10 Mbps or 100 Mbps.None of this information is very well hidden.
- marindavidJan 13, 2020Aspirant
With me, the problem turned out to be with Comcast/Xfinity. It took them 5-months to get my area up to GB speed and, in that time, they credited my monthly bill with an amount equal to what the speed upgrade had cost me. Now, my desktop, which is hard-wired to the Netgear Modem, measures at 375-600 Mbps. When it falls below that, I reboot the modem and, quickly, all is well again. The problem is not always our hardware or US!
- VPNTroubleJan 13, 2020AspirantI think the problem was comcast made some type of boot file that made the netgear not capable to handle the gig speed. Maybe all it would have took was raising a limit in the netgear set up but comcast was not going to tell us. I battled for several weeks and as soon as I installed there doc 3.0 gateway I went from 400 to 900 plus. The modem I was using was doc 3.1. Sucks. You know comcast could have told me how to fix it but they would not cause it was my equipment.
- VPNTroubleJan 13, 2020AspirantI had the same problem. I had the warrenty so I returned it and they gave me a new one. I had the same problem with it. In the beginning I had the correct speed. After several comcast techs ,new cables I took my modem back for a refund and went with the rental. Did this fix your issue.
