kingtj
Feb 03, 2019Star
CM1150V and Comcast - can't get gigabit speeds?
I just upgaded my Comcast Xfinity "Blast" Internet speeds to Gigabit, which required I upgrde my DOCSIS 3.0 Motorola cable modem. I ordered Comcast voice service too, with this upgrade, so apparentl...
CoolioBeans
Oct 01, 2019Aspirant
After some INTENSE expiditions through the internet I fell upon this reddit post:
A guy reccomends pushing in the the ethernet cable gauranteeing a perfect fit, because anything above 100Mbps needs all 4 ethernet contacts connected if it detects any less it will default to less than 100Mbps. I thought this was crap so I tried and it worked!!! getting 200+Mbps on my 175Mbps plan. :mansurprised:
PLEASE SHARE THIS ON ALL OF THE FORUMS YOU'VE CHECKED ALREADY!! I WILL DO THE SAME!
VPNTrouble
Jan 13, 2020Aspirant
I had the same problem. I had the warrenty so I returned it and they gave me a new one. I had the same problem with it. In the beginning I had the correct speed. After several comcast techs ,new cables I took my modem back for a refund and went with the rental. Did this fix your issue.
