kingtj
Feb 03, 2019Star
CM1150V and Comcast - can't get gigabit speeds?
I just upgaded my Comcast Xfinity "Blast" Internet speeds to Gigabit, which required I upgrde my DOCSIS 3.0 Motorola cable modem. I ordered Comcast voice service too, with this upgrade, so apparentl...
antinode
Oct 01, 2019Guru
> [...] pushing in the the ethernet cable gauranteeing a perfect fit,
If the cables/connectors are good, then you shouldn't need to do
anything special to get a proper connection. "Click" should be all you
need.
> [...] anything above 100Mbps needs all 4 ethernet contacts connected
Anything above 100Mb/s needs all _eight_ conductors.
In any case, this is why Ethernet connectors frequently have
associated LED indicators. Visit http://netgear.com/support , put in
your model number, and look for Documentation. Get the User Manual.
Look for the LED descriptions. For example, in the CM1150V User Manusl
(page 8):
o Green. A powered-on device is connected to the Ethernet port
at 1000 Mbps.
o Amber. A powered-on device is connected to the Ethernet port
at 10 Mbps or 100 Mbps.
None of this information is very well hidden.
marindavid
Jan 13, 2020Aspirant
With me, the problem turned out to be with Comcast/Xfinity. It took them 5-months to get my area up to GB speed and, in that time, they credited my monthly bill with an amount equal to what the speed upgrade had cost me. Now, my desktop, which is hard-wired to the Netgear Modem, measures at 375-600 Mbps. When it falls below that, I reboot the modem and, quickly, all is well again. The problem is not always our hardware or US!
