TrunkMonkey
Mar 05, 2021Tutor
CM1150V bandwidth intermittentently drops to below 1 mbps with Xfinity
When I first got this modem, everything was awesome, fast, stable, low latency, and no Intel Puma chipset issues. But now I'm intermittently rebooting the modem up to 12 times a day when speed of my...
TrunkMonkey
Mar 06, 2021Tutor
I'm using Google WiFi at the moment. Speed testing wired with a desktop.
Here's a the status after a power cycle this morning that I needed to do to restore bandwidth.
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel 507000000 Hz Locked
Connectivity State OK Operational
Boot State OK Operational
Security Enabled BPI+
IP Provisioning Mode Honor MDD honorMdd(4)
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM256 20 507000000 Hz 2.7 dBmV 39.8 dB 0 0
2 Locked QAM256 4 405000000 Hz 4.5 dBmV 41.2 dB 0 0
3 Locked QAM256 5 411000000 Hz 4.1 dBmV 41.1 dB 0 0
4 Locked QAM256 6 417000000 Hz 4.7 dBmV 41.2 dB 0 0
5 Locked QAM256 7 423000000 Hz 4.3 dBmV 41 dB 0 0
6 Locked QAM256 8 429000000 Hz 4.6 dBmV 41.2 dB 0 0
7 Locked QAM256 9 435000000 Hz 5.1 dBmV 41.1 dB 0 0
8 Locked QAM256 10 441000000 Hz 4.3 dBmV 40.8 dB 0 0
9 Locked QAM256 11 447000000 Hz 4.5 dBmV 40.8 dB 0 0
10 Locked QAM256 12 453000000 Hz 4.6 dBmV 40.7 dB 0 0
11 Locked QAM256 13 459000000 Hz 3.6 dBmV 40.3 dB 0 0
12 Locked QAM256 14 465000000 Hz 4.1 dBmV 40.4 dB 0 0
13 Locked QAM256 15 471000000 Hz 3.8 dBmV 40.3 dB 0 0
14 Locked QAM256 16 477000000 Hz 3.1 dBmV 40.1 dB 0 0
15 Locked QAM256 17 483000000 Hz 3.9 dBmV 40.3 dB 0 0
16 Locked QAM256 18 489000000 Hz 3.1 dBmV 40 dB 0 0
17 Locked QAM256 19 495000000 Hz 2.9 dBmV 40 dB 0 0
18 Locked QAM256 21 513000000 Hz 3 dBmV 39.9 dB 0 0
19 Locked QAM256 22 519000000 Hz 3.3 dBmV 39.9 dB 0 0
20 Locked QAM256 23 525000000 Hz 2.5 dBmV 39.7 dB 0 0
21 Locked QAM256 24 531000000 Hz 3.3 dBmV 39.9 dB 0 0
22 Locked QAM256 25 537000000 Hz 3 dBmV 39.8 dB 0 0
23 Locked QAM256 26 543000000 Hz 2.6 dBmV 39.7 dB 0 0
24 Locked QAM256 27 549000000 Hz 3.5 dBmV 39.9 dB 0 0
25 Locked QAM256 28 555000000 Hz 2.6 dBmV 39.6 dB 0 0
26 Locked QAM256 29 561000000 Hz 2.5 dBmV 39.5 dB 1 0
27 Locked QAM256 30 567000000 Hz 2.8 dBmV 39.5 dB 3 0
28 Locked QAM256 31 573000000 Hz 1.8 dBmV 39.1 dB 2 0
29 Locked QAM256 32 579000000 Hz 2.3 dBmV 39.3 dB 3 0
30 Locked QAM256 33 585000000 Hz 2.5 dBmV 39.4 dB 1 0
31 Locked QAM256 34 591000000 Hz 1.7 dBmV 39.2 dB 2 0
32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1 Locked ATDMA 5 5120 Ksym/sec 17300000 Hz 45 dBmV
2 Locked ATDMA 6 5120 Ksym/sec 23700000 Hz 46.5 dBmV
3 Locked ATDMA 7 5120 Ksym/sec 30300000 Hz 47.5 dBmV
4 Locked ATDMA 8 5120 Ksym/sec 36700000 Hz 47.5 dBmV
5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
Downstream OFDM Channels
Channel Lock
Status Modulation /
Profile ID Channel
ID Frequency Power SNR /
MER Active Subcarrier
Number Range Unerrored
Codewords Correctable
Codewords Uncorrectable
Codewords
1 Locked 0 ,1 ,2 ,3 48 850000000 Hz 4.1 dBmV 40.0 dB 1108 ~ 2987 7026860 6786467 0
2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0
Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power
1 Not Locked 0 0 0 Hz 0 dBmV
Current System Time:Sat Mar 06 04:36:59 2021
System Up Time:00:29:49
Startup Procedure
Channel Lock
Status Modulation /
Profile ID Channel
Codewords
TrunkMonkey
Mar 06, 2021Tutor
Here's the status of when bandwidth was near zero and speed test failed to load
Startup Procedure
1 Locked QAM256 20 507000000 Hz 3 dBmV 39.9 dB 0 0
2 Locked QAM256 4 405000000 Hz 5.1 dBmV 41.2 dB 0 0
3 Locked QAM256 5 411000000 Hz 4.6 dBmV 41.1 dB 0 0
4 Locked QAM256 6 417000000 Hz 5.1 dBmV 41.3 dB 0 0
5 Locked QAM256 7 423000000 Hz 4.8 dBmV 41.1 dB 0 0
6 Locked QAM256 8 429000000 Hz 4.9 dBmV 41.2 dB 0 0
7 Locked QAM256 9 435000000 Hz 5.4 dBmV 41.2 dB 0 0
8 Locked QAM256 10 441000000 Hz 4.7 dBmV 40.9 dB 0 0
9 Locked QAM256 11 447000000 Hz 4.9 dBmV 40.9 dB 0 0
10 Locked QAM256 12 453000000 Hz 5 dBmV 40.7 dB 0 0
11 Locked QAM256 13 459000000 Hz 4 dBmV 40.4 dB 0 0
12 Locked QAM256 14 465000000 Hz 4.5 dBmV 40.5 dB 0 0
13 Locked QAM256 15 471000000 Hz 4.2 dBmV 40.3 dB 0 0
14 Locked QAM256 16 477000000 Hz 3.5 dBmV 40.2 dB 0 0
15 Locked QAM256 17 483000000 Hz 4.3 dBmV 40.4 dB 0 0
16 Locked QAM256 18 489000000 Hz 3.5 dBmV 40.1 dB 0 0
17 Locked QAM256 19 495000000 Hz 3.2 dBmV 40 dB 0 0
18 Locked QAM256 21 513000000 Hz 3.3 dBmV 40 dB 0 0
19 Locked QAM256 22 519000000 Hz 3.7 dBmV 40 dB 0 0
20 Locked QAM256 23 525000000 Hz 2.8 dBmV 39.8 dB 0 0
21 Locked QAM256 24 531000000 Hz 3.5 dBmV 40 dB 1 0
22 Locked QAM256 25 537000000 Hz 3.4 dBmV 40 dB 1 0
23 Locked QAM256 26 543000000 Hz 2.9 dBmV 39.8 dB 0 0
24 Locked QAM256 27 549000000 Hz 3.8 dBmV 39.9 dB 1 0
25 Locked QAM256 28 555000000 Hz 3 dBmV 39.2 dB 0 0
26 Locked QAM256 29 561000000 Hz 2.9 dBmV 39 dB 4 0
27 Locked QAM256 30 567000000 Hz 3.1 dBmV 39.6 dB 6 0
28 Locked QAM256 31 573000000 Hz 2.2 dBmV 39 dB 9 0
29 Locked QAM256 32 579000000 Hz 2.6 dBmV 39.3 dB 12 0
30 Locked QAM256 33 585000000 Hz 2.9 dBmV 39.6 dB 8 0
31 Locked QAM256 34 591000000 Hz 2.1 dBmV 38.9 dB 10 0
1 Locked ATDMA 5 5120 Ksym/sec 17300000 Hz 55.3 dBmV
2 Locked ATDMA 6 5120 Ksym/sec 23700000 Hz 54.8 dBmV
3 Locked ATDMA 7 5120 Ksym/sec 30300000 Hz 54 dBmV
4 Locked ATDMA 8 5120 Ksym/sec 36700000 Hz 53.5 dBmV
Channel Lock
Status Modulation /
Profile ID Channel
Codewords
1 Locked 0 ,1 ,2 ,3 48 850000000 Hz 4.2 dBmV 39.9 dB 1108 ~ 2987 60633272 56983669 0
Current System Time:Sat Mar 06 08:01:50 2021
System Up Time:03:54:40
I'm also cross posting on an xfinity forum
Startup Procedure
Channel Lock
Status Modulation /
Profile ID Channel
Codewords
