Badexperience
Feb 16, 2023Tutor
CM1150v comcast link aggregation suddenly failed after 8 months
The CM1150v was connected to an ORBI RBRE 960 via Xfinity. Link aggregation was active and speed tests showed a regular download of 1300+ or -. After approximately 8 months, the ORBI would not conn...
Feb 16, 2023Guru - Experienced User
What have you tried to resolve this?
Power cycled the modem and RBR OFF for 2 minute then back on?
Any factory resets on both units and setup from scratch?
What CAT# LAN cables are you using between the modem and RBR?
What FW is loaded on the modem and RBR?
Any recent updates to both units?
