suspen
Oct 25, 2019Guide
CM1150v constant issues connecting
We used to have Comcasts all-in-one modem/router before we switched over to this new setup. When we had that old setup there was intermittent service from them but it wasn't as frequently down as it i...
suspen
Oct 25, 2019Guide
Keeping the ethernet plugged in hardwired to the MAC, I am now getting a bad phone line singal. People complaining the signal is not good and they cannot hear me well. That is a first.
suspen
Oct 25, 2019Guide
The other half of my screenshot.
- suspenOct 26, 2019Guide
No input from any one? If I can't find a solution on this we are going to move to Verizon services and get another modem. I don't think the Google Mesh system is at fault here.
- FURRYe38Oct 28, 2019Guru - Experienced User
Sounds like the ISP hasn't fully got the signal and line quality stablized up to the modem.
Be sure there are no cable coax line splitters between the ISP service box and modem.
Be sure you are good good quality RG6 coax cable up to the modem.
Try another CM modem to see if maybe the one you have could be faulty.
