Espious
Mar 03, 2021Aspirant
CM1150v Crashing and Needing to Be Physically Restarted
I've been having this problem with the CM1150V for awhile now. It'll be working fine for awhile, then the modem will disappear off of the network with the webpage being inaccessable from even a direc...
Mar 03, 2021Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly. Ask them to update FW if they can and it's available.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
What brand and model# external wifi router do you have connected with the modem?
Espious
So I went through the whole diagnosis process with the ISP, and from their end
the connection seems crystal clear.
EDIT: I agree too, 1gbps up until the modem decides it's had enough it seems like.
