MadDog97
Aug 16, 2020Tutor
CM1150V Downlink Light Flashing
My CM-1150V Cable Modem has in issue where the downlink light starts flashing, but everything is working correctly. The modem status shows no issues. When this happens, I've received two CM-STAT...
MadDog97
Aug 20, 2020Tutor
The cable connection page shows the same results, whether the light is blinking or not, and the modem is working fine.
My original question was that I believe the flashing downlink light, caused by a CM-STATUS message Event type code 20, isn't turned back to a solid light when a CM-STATUS message Event type 22 is posted.
Now, why I get these errors, I have no idea. The time between the messages is usually around 30 seconds or so.
Wallie
Nov 19, 2020Tutor
MadDog97 wrote:The cable connection page shows the same results, whether the light is blinking or not, and the modem is working fine.
I have the exact problem. Gigabit internet works fine and speedtest results in the 900Mbps range. Not sure why the downstream LED is always blinking. Maybe a firmware bug?
- MadDog97Nov 19, 2020Tutor
That's what I was asking. Is there a firmware bug that allows the downlink light to keep flashing after an error is cleared. On another note, the errors seen in my logs have almost disappeared. I used to get 10 - 20 errors a day, now I see one error every few days.
