Ron-M
Apr 18, 2020Aspirant
CM1150V Horrible stability on Xfinity
I was a very early user of the CM1150V (I can elaborate further, if necessary) and at the time it worked fine with my Xfinity service, but LACP was not yet enabled. I switched to an ARRIS T25 last y...
Ron-M
Apr 26, 2020Aspirant
plemans wrote:I've so far only had issues with the consumer implementations of link aggregation. Some are on the router side, some are on the modem side. I've tried the netgear cm1100 and the arris sb8200. Neither were 100% stable on it.
I wouldn't recommend using it.
Most users aren't going to saturate a gigabit connection and if they do, its for brief periods. Even testing sites struggle to saturate gigabit.
Thanks for the reply. I wouldn't say I had a high priority on getting it working, but maybe it's an even lower priority based on your info.
With that said, I still wouldn't mind anyone else's input on why the CM1150V could be so unstable/unreliable for me.
Apr 27, 2020Guru - Experienced User
do you have a screen snip of your modem's cable connection page and your logs?
