hockeypuck
May 30, 2020Star
cm1150v issue with phone service and speed.. xfinity
I have spent a few hours, 2 different times with xfinity operators trying to fix my modem issues. No phone and can not reach my subscription speed (600) but the first is more important. Tried a num...
May 30, 2020Guru - Experienced User
shouldn't need a reboot. just call xfinity and have them reprovision it.
hockeypuck
May 31, 2020Star
Just to update everyone.. spent too much time on the phone with xfinity. It was wiered that they could not even ping my router saying it was offline even though I have internet. Tech is coming out tomorrow. I wonder if my splitter it not the correct type. It was installed by comcast 10 years ago. Its a 2 way splitter, 5-1000mhz. -3.5 db out.
- FURRYe38Jun 01, 2020Guru - Experienced User
What happens if you remove the splitter?
- hockeypuckJun 07, 2020Star
Update. It appears that the line coming into the house was old. Insulation was crumbling and water logged. Replaced the line. Installed a new modem while they were here. Will try reinstalling the cm1150 later this month and send the factory one back.
- FURRYe38Jun 07, 2020Guru - Experienced User
Let us know when you try the CM modem.
