MikeCoolGuy17
Jun 17, 2019Aspirant
Cm1150V Issues With Channels Any Advise?
Hello New to the fourm. I'm haveing issues i have gig internet from comcast. ionly have 3 locked bonded upstream channels I know there should be 4. I only have 31 downstream channels locked. and some...
Jun 18, 2019Guru - Experienced User
Check for any cable line splitters and remove them if seen.
Contact the ISP and have them check there signal up to the modem.
- MikeCoolGuy17Jun 18, 2019Aspirant
Thank you for that. Ive benn in contact with comcast they say everything is good. I tried talking with them 4 different times and all say is good. Ido have a splitter there as one goes to my cable box. but tried it with out it with the same results. Any other suugestions? Thanks.
- FURRYe38Jun 18, 2019Guru - Experienced User
Try a different CM modem. It's possible that your one unit could be faulty.
thats going to be a pain to return to bestbuy then going thu the hassle with comcast again. it did reach 900mbps on fast.com. Is that a good test website for speeds?
