MikeCoolGuy17
Jun 17, 2019Aspirant
Cm1150V Issues With Channels Any Advise?
Hello New to the fourm. I'm haveing issues i have gig internet from comcast. ionly have 3 locked bonded upstream channels I know there should be 4. I only have 31 downstream channels locked. and some...
Jun 18, 2019Guru - Experienced User
Check for any cable line splitters and remove them if seen.
Contact the ISP and have them check there signal up to the modem.
MikeCoolGuy17
Jun 18, 2019Aspirant
Thank you for that. Ive benn in contact with comcast they say everything is good. I tried talking with them 4 different times and all say is good. Ido have a splitter there as one goes to my cable box. but tried it with out it with the same results. Any other suugestions? Thanks.
- FURRYe38Jun 18, 2019Guru - Experienced User
Try a different CM modem. It's possible that your one unit could be faulty.
- MikeCoolGuy17Jun 18, 2019Aspirant
thats going to be a pain to return to bestbuy then going thu the hassle with comcast again. it did reach 900mbps on fast.com. Is that a good test website for speeds?
Ya we know. Need to check to see if different modem does samething to compare.
I use Ooklas installable speedtest app for Windows or Apple.
