networksteve
Jun 08, 2021Aspirant
CM1150V LACP maximum throughput issues per port
Does anyone know if there has been some progress made on the LACP issues for CM1150V and Xfinity? I currently have 4.02.02 pushed and while aggregation is working, I am being limited on throughput pe...
Jun 08, 2021Guru - Experienced User
Something to contact NG support about to let them know what your experiencing.
Each port on the Cm modem is rated at 1000Mpbs max connection rate. so at most, on a 1000Mpbs wired connection, you'll only see around 900Mpbs on a single port. If you can use LAG on a router or PC that can connect with LAG enabled, then I presume you should see well over 1000Mpbs. Depends if you can take advantage of this speed on the client side as well.
Good Luck.
- networksteveJun 09, 2021Aspirant
How do I report this? It wants a support contract for almost the cost of the device for me to be able to open a case. I'm not paying for a support contract to report an issue with their firmware that they are well aware of and has never worked since the product shipped. Any recommendations on getting this firmware issue submitted?
- FURRYe38Jun 09, 2021Guru - Experienced User
