Scott_UU
Apr 13, 2019Star
CM1150V LED says Partial Service, but all channels locked
I initially had some "partial service" issues, where only (2) of (4) upstream channels were locking. The GUI said "partial service" above the channel lists, and the upstream light was flashing -- an...
Apr 15, 2019Guru - Experienced User
I recommend you guys contact your ISP. They have control over how this modem gets associated with there sysetm. Have them look in to there logs.
Has a reset been performed on the modem yet?
Scott_UU
Apr 15, 2019Star
I have been in contact with Comcast, and verified that ALL PROVISIONED CHANNELS ARE LOCKED -- upstream and downstream. And yes, the modem has been power cycled, and even factory reset multiple times. Always same result.
All provisioned channels are locked, and the modem's GUI does *not* indicate partial service -- nor are there any partial service errors in the logs. But the upstream LED is still flashing.
Looks like a firmware bug to me. Odd that Netgear won't answer.
- FURRYe38Apr 15, 2019Guru - Experienced User
It's probably a HW problem. I would try another CM1150v.
Others have not methioned this and FW comes from ISPs after NG give it to the ISP to test out on there system.
- Scott_UUApr 15, 2019Star
No, it's probably not a HW problem. LOL. I *have* tried (2) CM1150V's, and both behave the same. Both have latest firmware, v2.02.03.
I initially had problems locking all (4) upstream channels, and the CM1150V correctly said "partial service" in the GUI and the upstream LED was flashing. I bought a second CM1150V specifically to prove to ISP that it was not HW. Comcast susequently found and removed a filter at the pole, and that solved the channel lock problem.
Now all provisioned channels, upstream and downstream, are locked. The GUI no longer says "partial service", but the upstream LED is still flashing as if there was a partial service problem. So the GUI and the LED are contradicting each other. Sure sounds like firmware to me.
Someone from Netgear needs to take a look at it.
