Santa_Cruzer
Dec 23, 2020Guide
CM1150V modem frequent and long reconnects more recently - upstream channel issue.
Hi, I found this forum somewhat helpful and and going to post my experience troubleshooting a problem with the CM1150V. I have not found root cause, but seem to have resolved it for now swapping ou...
Dec 23, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
What Firmware version is currently loaded on Orbi?
Santa_Cruzer
Dec 24, 2020Guide
Thanks for your response, I'm aware of all the standard troubleshooting.
When wired directly with no splitters, it made no difference - it would disconnect often and take up to 20 Minutes or more to reconnect. In fact, it almost seemed worse, going beyond 20 minutes to try and establish a connection. It was provisioned 9 months ago when installed and has worked well up until recently, Does re-provisioning make any differences that might resolve this situation?
I don't understand why having ISP check signal on my line (coming out and measure) when another modem seems to work fine without disconnects for 2 days now? That would seem to isolate the problem to my cm1150v modem.
ISP said my cm1150v modem is working fine from their end with their online status check, although I suspect this health diagnosis is quite rudimentary.
Always good to have tech come and measure line quality, I could probably force them to do it, that usually takes some time. With a T25 working fine, with seemingly healthier upstream status, I'm having a hard time justifying a tech visit to save the CM1150v that has gone bad, or was bad from the beginning and recent operating conditions moved it to operate marginally.
If I had a rational explanation why the CM1150v might still be good, I might go through that trouble.
I don't understand your question on Orbi firmware version. the Orbis continue to run fine on my home network when cm1150v modem disconnects often from ISP. They work really good, best signal I've ever had here by far. Are there known firmware issues here that could result in modem connection to ISP frequently dropping? If so, maybe you could bring to light?
- FURRYe38Dec 24, 2020Guru - Experienced User
If a different modem works and seems to resolve the problem, then possible the CM modem could be faulty. Something to contact NG support about.
There are some versions of Orbi FW that cause problems. There is a reason for asking about FW version.
- Santa_CruzerDec 24, 2020Guide
Thanks for your reply.
I may take up with NG as the burden will be on them now and may still be under warranty. I'll leave it here for others in case they run into similar issues.
I'd rather avoid disclosing too much about my network hardware and software. I already have logged a few "visitors" from time to time, showing up trying to crack usernames and passwords.
For troubleshooting and helping users out. It's ok to give FW versions. It helps us help you.
Good Luck.
