RAXXXSTER
May 28, 2020Initiate
CM1150V no upload speed
I bought the CM1150V on May 12, 2020 and it arrived on May 20, 2020. It failed to work properly the morning after I had it provisioned. It took me 2 days to get it up and running. It worked at 950/40 ...
Mikey94025
May 28, 2020Hero
This is the Orbi AX mesh router community. I think you want to post about your CM1150V cable modem in: https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
