Psychox
Apr 02, 2020Tutor
CM1150V Not allowing network router to connect to Internet.
Today I bought a Netgear CM1150V Xfinity modem. (2nd of April 2020) Setup was easy. The firmware is the most up to date for today. The problem is the modem is blocking my routers from conecting to th...
MacroLogo
May 21, 2020Aspirant
I had a very similar problem. I ultimately solved it by having my entire system connected as I wanted it (i.e., the ethernet cable connected between the cable modem and the wifi router), with everything powered on, then called Comcast/Xfinity on my cell phone. I verbally spoke the option "no internet connection" when the robot asked me to describe my problem at which point the robot reset my entire system remotely. It sent me a text message saying it was starting the reset and then hung up on me. Ten minutes later I got a message that my system had been reset. At that point, I was able to go through Netgear's protocol of setting up my new Wifi router, which included updating the Wifi router's firmware. It was however, obvious as soon as Xfinity had reset my system that things were going to work.
Further comments
1. I spent many hours trying to troubleshoot this before hitting upon the relatively quick solution above.
2. I called Comcast/Xfinity twice before my successful call. For these first two calls I had said I need to "Activate my system". Each time I was connected to a human. The first human got my information then tried to transfer me to an activating agent at which point my call was dropped by Comcast. The second agent insisted that I did not need to activate, said she had been working for Comcast for 20 years, that she could not possibly be wrong, and hung up on me. So the trick was getting a robot, not a human.
3. Comcast documentation and human advice seem to convey that once the cable modem is working, it doesn't matter what is hooked up downstream. This is demonstrably false. I was able to hook up only one device at a time (my old wifi router, or my computer directly, or my new wifi router, or another computer). In order to swap these out, I needed to use my cell phone to call Comcast and have the robot reset my entire system. In the case of directly connecting a computer, there was a way to do this directly form the computer browser, but I couldn't figure out how to do this directly with a wifi router.
4. Before hitting on the correct solution, I tried a number of tricks, like setting a static IP to the router equivalent to the IP that Comcast had previously assigned my desktop computer. But I was not successful.
5. I was getting close to giving up and surrendering and buying an Xfinity Gateway. Xfinity definitely has a conflict of interest in providing advice or making it easy to connect your own gear.
6. It wasn't strictly true that I had "no internet connection" because I did have a connection through my desktop computer. I just couldn't figure out how to change that connection to the wifi router.
7. I was not able to update the Netgear Nighthawk router's firmware until after I had the system reset by Comcast.
8. Merely turning off the power to the cable modem does not work. It has to be reset remotely by Comcast.
9. After posting my original message in another thread, someone suggested a Factory Reset of my cable modem (using the button on the modem) would work equivalently to having Comcast reset my modem remotely. I did not try this, but I suspect it would not have worked for me, as there seems to be a phenomenon of Comcast knowing what I have plugged in downstream. Not sure how, maybe through the MAC address. So you might try the factory reset button. But it is probably just as easy to have Comcast do it remotely unless you don't have a way of phoning them with a cell phone or other phone.
- FURRYe38May 21, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.You can factory reset the CM modem your self as well. There is a reset button on the modem. Press and hold it for 15 seconds then release.
- PsychoxMay 21, 2020Tutor
My brother is one of them high IQ computer nerds with no education. After downloading the firmware off the modem. He found a line where Comcast was in fact blocking use of an external wireless router. They want you to rent their equipment and this is how they do it. I had one of two choices. I could rewrite the line in the firmware and have to rewrite it every time Comcast did a firmware update or set my router up as an access point so eveything on that router was pulling an IP from the modem. I doing this I ended up buying another router just to use as an AP. Once I setup the AP I was able to trick the system and hook up my other 4 routers as normal routers and not in access point mode.
It's funny people ask me all the time, "why do you want to sit behind 4 routers."
Here's why: I use them as part of a custom firewall. I have an old pentium 3 sony viao desktop hooked to all 4 routers. It does a few different things, but its main peruses are to scan my network for trojan programs, nesting programs, and foreign mac addresses that are not in a set list. When it finds a foreign mac address it drops a nesting program with a trojan virus onto the device with the foreign mac address. The nesting program does 4 things. 1. It replicates it's self and sends out copies to every device on the foreign devices network including the modem and routers. 2. It roots its self into the firmware and bios of every device on the network. 3. Its locks down all the data on all the hard drives in the network. 4. It forces an over clock of the frontside bus to 8.3ghz on all computers on the network.
I have to love my little brother for this program. It runs on MSdos, but it won't run in windows. It is a patented and copie written stand alone operating system that has never been distributed.- FURRYe38May 21, 2020Guru - Experienced User
CC allows users to connect routers of there choice to there modems or user bought modems. There would lots more people posting problems with CC if this was really blocking users from connecting external routers. Most common configurations and normal for most house holds is having 1 router. Thought I presume you could have more if you wanted too. Thought this would be problematic at best. Seems to be a problem in your case which nobody else seems to be having.
Good Luck.
