Psychox
Apr 02, 2020Tutor
CM1150V Not allowing network router to connect to Internet.
Today I bought a Netgear CM1150V Xfinity modem. (2nd of April 2020) Setup was easy. The firmware is the most up to date for today. The problem is the modem is blocking my routers from conecting to th...
May 21, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
You can factory reset the CM modem your self as well. There is a reset button on the modem. Press and hold it for 15 seconds then release.
Psychox
May 21, 2020Tutor
My brother is one of them high IQ computer nerds with no education. After downloading the firmware off the modem. He found a line where Comcast was in fact blocking use of an external wireless router. They want you to rent their equipment and this is how they do it. I had one of two choices. I could rewrite the line in the firmware and have to rewrite it every time Comcast did a firmware update or set my router up as an access point so eveything on that router was pulling an IP from the modem. I doing this I ended up buying another router just to use as an AP. Once I setup the AP I was able to trick the system and hook up my other 4 routers as normal routers and not in access point mode.
It's funny people ask me all the time, "why do you want to sit behind 4 routers."
Here's why: I use them as part of a custom firewall. I have an old pentium 3 sony viao desktop hooked to all 4 routers. It does a few different things, but its main peruses are to scan my network for trojan programs, nesting programs, and foreign mac addresses that are not in a set list. When it finds a foreign mac address it drops a nesting program with a trojan virus onto the device with the foreign mac address. The nesting program does 4 things. 1. It replicates it's self and sends out copies to every device on the foreign devices network including the modem and routers. 2. It roots its self into the firmware and bios of every device on the network. 3. Its locks down all the data on all the hard drives in the network. 4. It forces an over clock of the frontside bus to 8.3ghz on all computers on the network.
I have to love my little brother for this program. It runs on MSdos, but it won't run in windows. It is a patented and copie written stand alone operating system that has never been distributed.
- FURRYe38May 21, 2020Guru - Experienced User
CC allows users to connect routers of there choice to there modems or user bought modems. There would lots more people posting problems with CC if this was really blocking users from connecting external routers. Most common configurations and normal for most house holds is having 1 router. Thought I presume you could have more if you wanted too. Thought this would be problematic at best. Seems to be a problem in your case which nobody else seems to be having.
Good Luck.- PsychoxMay 22, 2020Tutor
FURRYe38 Yes you can hook up a router, but the Docsis 3.1 on Comcast blocks them in a normal router config. If you use the Access Point mode on your router you can use them all you want, but you will lose a level of security. This is because your router is assigning the IP address given to it from the modem. So, if your modem has a user control IP address of 10.0.0.1 and you run your router in Access Point mode all your devices are going to be 10.0.0.2, 10.0.0.3, 10.0.0.4, etcetera. However, if your router is running in a router mode you have an extra level of security. This is because a router in router mode is giving your devices a different IP address. So, your router asks your modem for an IP address. The modem gives it 10.0.0.2. Most routers have a user control IP address of something like 192.168.0.1. If the router is in router mode and not in AP mode it is going to give all your devices IP addresses of 192.168.0.2, 192.168.0.3, 192.168.0.4, ectetera. It is much harder to find a device behind a router when you're hacking someone's network. Because, the router user controls IP addrss might be set to 75.75.75.75 (FYI: this is comcast's DNS server IP out of Chicago) and all their devices might be running 75.75.75.76, 75.75.75.77, 75.75.75.78, etcetera. The router user control IP address can be anywhere from 1.0.0.1 to 255.255.255.254. There are programs that can scan for the IP addresses of the devices, but it's going to take a long time to get it done. If the person you are hacking is sitting behind multiple routers before you can get to their devices it's going to take some time to get to them. There are ways to drop the time it will take such as in PvP game play or through a messanger program on social media, but not everything you want to hack is going to be that easy.
- FURRYe38May 22, 2020Guru - Experienced User
Something you might check with other CC forums and see. I've seen many users post about having CC and use there own modems and own routers with little problems. I know this for sure as I've beta tested for NG had they ask us which ISP we use before we start testing. CC is one on a short list the NG asks us about. Seems like something maybe your doing or using isn't configured right. Again, if CC was doing this, there would be many users angry about not being able to use there own bought products on there network.
