RossS
Sep 10, 2020Aspirant
CM1150v notice 6 message
I keep getting this notice: CM-STATUS message sent. Event Type Code: 16; Chan ID: 29; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=28:80:88:d4:29:28;CMTS-MAC=00:01:5c:ad:ea:57;CM-QOS=...
- Sep 12, 2020
Maintance person for xfinity came and checked outside feed to my neighbor hood (my part) and found problem. Now all dBmV values are in spec. Thank you for the help.
Sep 10, 2020Guru - Experienced User
Log into the modem and get a screen shot of the cable connections page and the complete lots. Not just 1. they're used together.
RossS
- RossSSep 10, 2020Aspirant
- plemansSep 10, 2020Guru - Experienced User
Your power levels are out of spec. You should be between -7.5dbmv ad 7.5dbmv. You should also only see about a 3.5dbmv difference betweenthe channels. You're running from -14.9 to -8.6.
If you have any splitters, amplifiers, attenuators in the coax line, remove them. If this doesn't help, you'd need your isp to check the line.
