TomK325's avatar
TomK325
CM1150V orientation
Is there any restrictions on the orientation of this modem?  Airflow?  I wish to place it horizontally in my vented cabinet.  Temperature runs between 85-90 degreesF. Cabinet space is 9" H.
  • > Is there any restrictions on the orientation of this modem? [...]
       Did you find any restrictions in the product documentation?
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get some.  Read?
    > [...] Airflow? [...]
       I know nothing, but I'd guess that any such restrictions would be
    related to heat.  If you blow more air at/through it than it would
    normally move on its own by convection, then I wouldn't expect any
    thermal problems in any orientation.
       Whenever you blow air, you blow dust, so more attention to cleaning
    would be appropriate.
    • TomK325's avatar
      TomK325
      I downloaded all the documentation that was available.  Nothing in there.  Checked for other "tuitorial" type documents and nothing surfaced.  I have the CM500V and its constructio is nothing like the CM1150V - too bad.  Like you I suspect it might be heat related - the faster the modem the more power required, etc.  The pictures don't help but it looks like more open construction that the CM500V maybe for heat dissapation.  Thanks for responding.
