stephenie89
Feb 26, 2020Aspirant
CM1150v plugged into wall phone outlet but no phones in house work
I have the CM1150v modem with voice, have xfinity voice service. If I plug a phone into the back of the modem, phone service works. I need to connect the modem to my wall jack to serve all the phones...
Feb 27, 2020Guru - Experienced User
If a phone works directly connected to the CM modem, and not with the modem connected to your home phone wall jack, I would presume the problem would be the wall phone jack and cabling in the home needs to be looked in to. Check to see if the CM modem fully supports being connecte to a in wall phone jack system.
stephenie89
Feb 27, 2020Aspirant
I know the phone jacks & wiring in the house work. Just switched from traditional landline phone service back to Xfinity voice. I have searched for info and can't find anything that talks about whether this CM1150v modem works with just one phone or the whole house. Not sure why it would just work with one phone, thats kind of pointless considering it is supposed to be the alternative to the xfinity rented equipment. It just seems I must be missing a step or equipment to get the modem to push the dial tone to all the phone jacks
- FURRYe38Feb 27, 2020Guru - Experienced User
Was the main phone line disconnected from the outside phone line on the pole or main phone switch box that connects to the phone pole or service box out side? Possible that this maybe causing problems. Maybe isolate the phone jack system from the phone pole/service box outside and see.
- stephenie89Feb 27, 2020AspirantWill try that, thanks for the idea!
- vkdeltaFeb 28, 2020NETGEAR Employee Retired
yes, please disconnect any other non-comcast/xfinity lines.
let us know if works after that.
also, please share few pictures of your setup and wall jacks.
If you draw a quick diagram, it would be great.
- stephenie89Feb 28, 2020AspirantStill not working. Disconnected the phone line in the phone box on the outside of the house. I've attached pictures of the back of my modem with the phone wire, and a second picture of that wire plugged in the wall phone jack. We have multiple phone jacks in the house but only have phones connected to 3. I've checked all the wall jacks in the house, no dial tone. I don't know why the dial tone isn't going into our house phone wiring from the modem. If I plug a phone into the modem directly, that phone works. Any tips will be appreciated!
