stephenie89
Feb 26, 2020Aspirant
CM1150v plugged into wall phone outlet but no phones in house work
I have the CM1150v modem with voice, have xfinity voice service. If I plug a phone into the back of the modem, phone service works. I need to connect the modem to my wall jack to serve all the phones...
stephenie89
Mar 02, 2020Aspirant
Thats what I'm starting to think. Unfortunately, this one is already past the warranty (we've had it a year, just finally pulled the trigger on activating the voice service).
Mar 02, 2020Guru - Experienced User
Might contact the forum moderator and see what other options are avaialble to you. Wondering if the unit was faulty to begin with and you didn't know untill you activated VoIP. :smileyfrustrated:
- vkdeltaMar 02, 2020NETGEAR Employee Retired
do you have any other wall plugs to test with?
what was your previous equipment?
when was it tested last ? couple of months back or long back? do you have access to the main termination point (such as Bedroom closet where everything terminates). Have you checked wether all the wires are connected there?
- stephenie89Mar 02, 2020AspirantEvery phone jack is also a cable jack in our house. That is my next step- pull the modem out of our office, connect it to cable & phone in another room. Will update after I try that.
Previous to this, I had traditional phone landline. Several years back had Comcast voice for about 2 yrs before switching back to landline. I don't have a main termination point in my house, it all appears to be in the garage. Will look again, but everything I've checked looks to be good. And was all working just prior to Xfinity porting my number from the landline phone company. I really do not think its my wiring, I've checked everything I can see. Based on all the feedback here & on Xfinity site, I think its either the voice modem just isn't working right or my office phone jack picked the afternoon of my phone number finally porting over to break.
I appreciate all the attempts to help. Still hoping there is some trick I'm missing before I have to buy a new modem. - vkdeltaMar 03, 2020NETGEAR Employee Retired
I thought you had comcast xifnity just 1-2 months but looks like you had DSL type landline phone before this. I am not sure if they have modified the wiring.
Please make sure wiring in main closet is ok.
- What voice port connect to wall plug? Port 1 or port 2? Cany ou take photo
- What’s the voice LED (line1 / line2) status when eMTA online? Solid on? Flashing? Or?
- Can you capture eMTA voice status page, DOCSIS event log page.
- How many phones connect to wall plug?
- What kind of phone connect to wall plug? Can you take photo of each phone.
- Can you just plug one phone on wall plug and offhook, see if there is dial tone. If no, can you capture eMTA event log in GUI. If DUT detect offhook or onhook event, it will record the event in the event log.
- Same as step6, but connect phone directly to voice port 1, offhook and check dial tone, capture eMTA event log in GUI.
- stephenie89Mar 03, 2020AspirantNope, never had DSL. We had xfinity years ago, switch back to traditional phone line, just switched back to xfinity voice. Wires are fine, as I've already stated. Phone plugged into line 1 on back of modem works. Line 1 & 2 lights on modem are solid lit. When I plug cord from line 1 into wall, it doesn't power rest of house phones. Finally have some time to do more troubleshooting so will update as I've narrowed it down to 2 things.
- FURRYe38Mar 04, 2020Guru - Experienced User
Be sure your phone line cable between the modem and the wall jack is good. I recommend the 4 wire/pin cables over any two wire cables.
