Greg76
Nov 22, 2020Tutor
CM1150V Voice Not Working
I purchased the CM1150V from netgear to replace the Altice modem from Optimum so I could fully access my smart home systems. The modem was provisioned by Optimum when I called and internet works jus...
Nov 22, 2020Guru - Experienced User
Either ISP or a tech needs to check the phone lines in your home. You'll need to contac the ISP for help in this. If this worked on a different ISP and isn't working on the different ISP, then the newer ISP needs to look into this.
Greg76
Nov 24, 2020Tutor
It is the same ISP (Optimum). The only difference here is the modem.
- FURRYe38Nov 24, 2020Guru - Experienced User
Contact NG support as well.
- SShawnJan 09, 2021AspirantWondering if you got this to work with optimum if so how or what do I need to do I have same issue
- antinodeJan 09, 2021Guru
> need to do I have same issue> Model: CM1150V|DOCSIS 3.1 Nighthawk. Multi-Gig Speed Cable Modem for
> XFINITY(R) VoiceI know nothing, but does "optimum" offer "XFINITY(R) Voice"? I would
think not.Perhaps a forum search for "CM1150V" would find some useful
information. Mine found, for example:- Greg76Jan 09, 2021TutorHi. Working with Optimum is a brutal process. Speak to 5 different people and you’ll get 5 different answers on almost any topic. Modem says it’s for Xfinity but also compatible with other service providers and optimum actually told me to buy this modem. In the end, I also had an older modem (slower speed) that I used for my phone while my internet runs through this modem.
