deputylynch
Nov 09, 2022Aspirant
CM1150V Will not reset
I have a CM1150V that when powered up all the lights come on instantly and the unit will not reset no matter what I try including the 30-30-30 power cycle. Any suggestions on getting it reset and...
Nov 09, 2022Guru - Experienced User
Disconnect the ISP coax cable line from the modem. Press the reset button for 10 seconds then release.
Check for access of the modems web page after a minute with 1 wired PC connected to the port in back, can you access 192.168.100.1 at all? If you can, then connect the ISP coax cable to the modem.
- deputylynchNov 09, 2022AspirantNo matter what I do the unit seems to be a brick. It will not show up on a PC and all the lights just stay on no matter what I do to reset it.
