lsouza's avatar
lsouza
Follower
Mar 16, 2019
CM1150V will not work with either of my WiFi Routers or Voice service
I purchase the Netgear Nighthawk CM1150V tonight and spent over 5 hours on the phone with Comcast and Netgear but ended up having to switch back to my rental modem. For some reason the modem does not...
  • vkdelta's avatar
    Mar 18, 2019
    Please note that Most of the comcast services provides ONLY 1 IP.
    If you switch between Router vs PC, Please make sure to reset the modem everytime you do it.
