Boombar
Jul 02, 2020Tutor
CM1150v with xfinity dropps speeds soon after a reboot
I have cm1150v modem with xfinity 1Gb service.Firmware version is set by comcast, v2.02.04. I'm using 2 LAN port aggregation to RAX80 wifi router, they are both located near eachother. I measure...
Jul 03, 2020Guru - Experienced User
Its an issue with link aggregation. It seems like both netgear and arris have had issues with link aggregation and speed drops.
Its a great idea in concept but performs poorly on consumer devices.
I'd disable link aggregation and just run it with a standard 1 gig connection.
I switched from a cm1100 to the CAX80 just for the 2.5g ethernet port and the issues with link aggregation.
Boombar
Jul 04, 2020Tutor
I decided to change the 2 cables for agregation with 2 that are identical, in lenght and manufacturer. I also put aluminum foil between the wifi and the modem.
Surprisingly the Modem has been up to speed for couple of days now. If it drops again, i'll disconect the agregation and report back.
Thank you!
- BoombarJul 07, 2020Tutor
After few days with new cables for 2 LAN port aggregation, the speed droped again from >1gbs to ~20mbs. I disconnected the aggregation and now the speed lingers around 500mbs.
Sucks.
- FURRYe38Jul 07, 2020Guru - Experienced User
Please make contact with NG support about this. Let them know what your seeing.
Boombar wrote:After few days with new cables for 2 LAN port aggregation, the speed droped again from >1gbs to ~20mbs. I disconnected the aggregation and now the speed lingers around 500mbs.
Sucks.
I can't contact netgear.
Both modem and router were purchased last year and the support only lasts 90 days.
I could purchase some GearHead support for $90 for 6 months. Im sceptical the support would be of much help anyways so im not going to do that.
If nothing else- lessons learned.
