Boombar
Jul 02, 2020Tutor
CM1150v with xfinity dropps speeds soon after a reboot
I have cm1150v modem with xfinity 1Gb service.Firmware version is set by comcast, v2.02.04. I'm using 2 LAN port aggregation to RAX80 wifi router, they are both located near eachother. I measure...
Boombar
Jul 04, 2020Tutor
I decided to change the 2 cables for agregation with 2 that are identical, in lenght and manufacturer. I also put aluminum foil between the wifi and the modem.
Surprisingly the Modem has been up to speed for couple of days now. If it drops again, i'll disconect the agregation and report back.
Thank you!
Boombar
Jul 07, 2020Tutor
After few days with new cables for 2 LAN port aggregation, the speed droped again from >1gbs to ~20mbs. I disconnected the aggregation and now the speed lingers around 500mbs.
Sucks.
