brianiup
Apr 05, 2019Guide
CM1150V wont bind all upstream channels after upgade to firmware 2.02.03 (Partial service)
My service was working fine with 32 downstream 3 upstream and 1 OFDM channel locked under firmware 1.01 right after the upgrade to 2.02.03 the service is saying "partial service" and showing upsteam ...
ccopmpNB
Apr 23, 2019Aspirant
I'm haing the same issue. Only one of the 4 upstream channels will lock. Using a Comcast provided modem, all channels lock without issue. Cabling was replace by L3 tech and all signals scanned. Currently had to swap back to a Comcase gateway. Hopefully, it's just a firmware issue and I can get the Netgear back in service. I tried a 2nd CM1150V and had the same issue
brianiup
Apr 24, 2019Guide
Yeah, I can put any other modem on the same line and it lockes to all 3 upstream channels perfectly and no T-3 or T-4 errors in the even log... plug in the CM1150V and upstream won't lock more then 1 channel, partial service and upstream light blinks... it worked perfecetly up until the modem upgreated to 2.02.03 immediatly (littearly after the firmware updated) after that the problem started.
Sometimes it will lock one channel then channel 2 will try to lock on the same frequency and even list it as the 2nd one's frequency which is wrong. Maybe that is their bug?
and I get constant T-3 and T-4 errors since the firmware upgrade, cable tech says signals and lines are perfect. on an Arris modem I don't see any of these T-3 and T-4 errors..
