brianiup
Apr 05, 2019Guide
CM1150V wont bind all upstream channels after upgade to firmware 2.02.03 (Partial service)
My service was working fine with 32 downstream 3 upstream and 1 OFDM channel locked under firmware 1.01 right after the upgrade to 2.02.03 the service is saying "partial service" and showing upsteam ...
brianiup
Apr 24, 2019Guide
Comcast wont do that unless it's causing a major service disruption... and from everyone I've talked to "your internet still works" therefore it isn't one
ontop of that they basically try to guilt you with this problem into renting one of their crappy gateways instead
Apr 24, 2019Guru - Experienced User
Well they will have to check this since its on there system and there resposible for good operation and maintaining FW. You can try contacting NG to see if they have any suggestions or if this is a known issue. You might try another same model cablemodem to see if the problem continues. Could be bad HW as well. Try a CM1100 modem and see if it does the same thing. If it does, then both NG and CC need to address this.
- brianiupApr 24, 2019Guide
I've tried an Arris SBV3202, Motorola MB8600 and a Netgear CM1100 none of them showed this issue plugged into the same coax port...
I tried a second CM1150V and it displayes the same symptoms
- FURRYe38Apr 24, 2019Guru - Experienced User
Then thats something NG and CC will have too look into then.
Good Luck.
