andybluejay
Jan 17, 2024Follower
CM1150v won't boot
I think my CM1150v modem is bricked. Comcast was out here today and the tech tried to re-provision the modem but couldn't get it to connect, now it is stuck in a boot loop. The led sequence goes: ...
Jan 17, 2024Guru - Experienced User
IF he did a 30-30-30 reset with out the ISP coax cable connected and this failed to bring the modem back to normal operation, then the modem needs to be replaced.
