eXgU2q3NDNT3RTf
Dec 11, 2020Aspirant
CM1200 - Only One Locked Upstream Bonded Channel
I have a CM1200 paired with Spectrum service running firmware version 1.02.01. The modem reports only one locked upstream bonded channel. I occasionally experience (seemingly random) disconnects...
eXgU2q3NDNT3RTf
Yes sir. There are no line splitters between the modem and ISP service box.
In addition:
- Tech replaced my RG-6 with his own.
- Rebooted CM1200.
- Factory reset CM1200.
My event logs are filled with:
- Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
- Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
* MAC addresses redacted.
I doubt the modem is bad and welcome any additional options to explore.
Dec 11, 2020Guru - Experienced User
Check with NG support to see if there are any options available to you. Ask about an RMA.
- eXgU2q3NDNT3RTfDec 11, 2020Aspirant
I started the process to explore RMA options with NG, and was asked to pay for support in order to proceed since I am outside of 90-day window. I may try again, or keep exploring options online. This community deserves kudos however.
