WarrenWood
Apr 14, 2025Aspirant
CM1200 - Problem I've never seen before
I have a CM1200 that is 14 months old. Rock solid until yesterday. Starting in the morning, the modem started rebooting and the lights started a flashing in a pattern I've never seen before: Powe...
Apr 14, 2025Guru - Experienced User
Can you access the modems web page at all at 192.168.100.1?
Try this, disconnect the ISP coax cable from the the modem. Press the reset button for 15 seconds then release.
Check to see if power LED comes on solid then down led blinks. Up won't.
Connect one ethernet PC to port #1 on the back leaving the coax cable disconnected. Give about 2-3 minutes then attempt to access the modems web page at 192.168.100.1
Let us know results.
WarrenWood
Thank you! No success with any of the suggested steps. As a guess, I'm thinking it's not completing POST. Maybe a failed board, maybe a code update failed partway... who knows?
I guess it's time to replace it.
- FURRYe38Apr 14, 2025Guru - Experienced User
last resort you can try is a 30-30-30 reset, if this fails then ya, needs replacing.
- WarrenWoodApr 15, 2025Aspirant
After 30-30-30... "It's dead, Jim".
Thanks everybody!
- FURRYe38Apr 15, 2025Guru - Experienced User
Check out places like amazon, ebay or shopgoodwill for modems. I happened to find a CM1200 on shopgoodwill for $40 a couple of weeks ago for a friend of mine. đ
Good Luck.
