Telcontarr
Aug 26, 2020Aspirant
CM1200 + ASUS ROG Rapture GT-AX11000 Regular Download Speed Drops
Hello, I'm using the CM1200 and the ASUS ROG Rapture GT-AX11000 on a Spectrum 940mb download plan. Over the course of a day, from the moment the router is reset, my download drops to around 10-20m...
- Aug 26, 2020
Mostly general info, however NG compiles the code and does a quick check/test I presume, then NG works with ISPs and hands off any FW updates to the ISPs. ISPs then go thru there own testing to make sure it doesn't break anything on there network, I presume verifies FW works and any fixes are checked and then certifies it for there network if they approve. Once approved, for those ISPs that push to user owned modems, will push as seen with CC/XF. Some ISPs have policies that they will not push FW to user owned modems. Spectrum seems to be problematic in this area. :smileyfrustrated:
Aug 26, 2020Guru - Experienced User
Have the ISP push v2 FW to the CM modem. There was a recent update to the CM1200 that fixed the LAG enabled slowdown:
Thoght I see Spectrum is mentioned as not having it ready?
Telcontarr
I've contacted Spectrum and had to go through a few different conversations to even try and connect to someone who knows about this process. They've repeatedly just told me to contact Netgear to solve the problem. Is there any information on how the individual ISP's approve and deploy these firmware updates? I'd be interested to know if anyone keeps track of that progress.
- FURRYe38Aug 26, 2020Guru - Experienced User
