keeve
Jun 25, 2023Aspirant
CM1200 + R7000 speed issues
Hello all,
I am an Xfinity customer paying for a 1200 mbps plan.
Currently, i am getting somewhere between 20 and 50 mbps!
Here is the history:
A few weeks ago, an AT&T tech working on the neighbors yard cut my cable.
Technician came by and reconnected the cable. He tole me that CM700 Docsis 3.0 could not handle the speed i was paying for.
Suggested I get a 3.1. Hence I got the CM1200.
Was still not getting any speed improvement.
Today, a tech came by and checked the speed outside the house: 1900+ speed.
When directly connected to CM via ethernet, we go max 200 mbps.
He suggested I get a combo cm+router.
After that, I spent 2+ hours with a tech chat.....Issue still not identified.
I did learn how to login to the cm admin page and look at the cable connection page. Before I could send it to the chat, I lost connection.
Here are some screen shots from the page
| Hardware Version | 1.01 |
| Firmware Version | V3.12.03 |
| Cable Modem Serial Number | 6YC2267CD0670 |
| CM Certificate | Installed
Here is the downstreaminfo
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
I am at a loss as to what to try next. Any help/suggestion is appreciated.
The modem is less than 2 weeks old.
Thanks in advance.
- KitsapMaster
Help is available, however more information is needed.
With a direct Ethernet connection between your CM1200 and a computer of some type you report 200 Mbps throughput. You should see something around 940 Mbps due to the limit of a single 1 Gbps output port.
What operating system is running on that computer? Mac? Windows? If Windows, what version?
Are you sure the Ethernet cable is in good condition and at least a Cat 5e or better? Look on the cable insulation.
How are you measuring your throughput? Web browser? ISP test site? Recommend you download and install the Ookla stand alone test application. It eliminates web browsers and web sites from the test process.
The power levels you show are low, near the low end of the specification. Netgear modems specify power levels between +7 dBmV and -7 dBmV with ideal right at 0 or a little higher. For reference: https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
- keeveAspirant
Thanks for your response
With a direct Ethernet connection between your CM1200 and a computer of some type you report 200 Mbps throughput. You should see something around 940 Mbps due to the limit of a single 1 Gbps output port. I agree
Windows 10
The cable is one that came with the modem when I purchased it
xfinity suggests speedtest.xfinity.com
I also tried ookla (I will download it and try as you suggested)
Ok. I must say the coax cable in the house is as old as the house (40 years)
I will look at your link. Who can adjust power levels?
- KitsapMaster
Recent Windows updates have incorporated some new default features relative to network profiles. On your computer, go to Settings -> Network & Internet -> Status -> Ethernet Properties and make sure your network profile is set to private. If it is public, Windows throws a bunch of firewall features in your way that can limit throughput. A new modem is considered a new network by Windows and you might run in to the same thing again when you put your R7000 in play. If it is set to public, change the profile, restart your computer, and repeat the throughput test direct connected to your modem. Be sure your computer has a 1 Gbps Ethernet port and the Ethernet port drivers are up to date from your computer manufacturer.
For your own satisfaction, look at the outside insulation on your Ethernet cable to ensure it is Cat 5e or Cat 6. What did you find?
Be sure you install the Ookla stand alone test application and do not use a web browser and a web address for throughput testing.
Power levels are the responsibility of your ISP. Depending on what plan you purchase, the ISP may consider their responsibility to end at the connection box at your house and not at the connection to your modem. I recall Xfinity has an optional inside wiring add-on to your bill where they take responsibility for the wiring right up to the connection on your modem. You should check before you find yourself being billed for inside wiring work.
Do you have any coax splitters inside your house? Each one in series can reduce your power levels by 3.5 dB or 7 dB.
Regardless of when you bought it, the design of your R7000 is getting a little long in the tooth. Even so, it should handle nominal 1 Gbps throughput at the Ethernet ports. It will not be the same over Wi-Fi. The R7000 is not on the official End of Service list from Netgear.
I'd focus first on getting the cm1200 to full gigabit speeds before moving on to troubleshooting the r7000.
Its a solid router but its a decade old and certain settings can cause slowdowns with it.
do you have a copy of the cm1200's logs? those help test longer term connection stats
- keeveAspirant
I am primarily focused on the cm1200.
Here is what I found in the log.
Time Priority Description Mon Jun 26 13:36:43 2023 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Mon Jun 26 13:34:15 2023 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 18:16:54 2023 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 18:16:40 2023 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 18:16:35 2023 Notice (6) TLV-11 - unrecognized OID;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 17:47:23 2023 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 17:47:18 2023 Notice (6) TLV-11 - unrecognized OID;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:37:15 2023 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:36:59 2023 Notice (6) CM-STATUS message sent. Event Type Code: 22; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:34:36 2023 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:34:27 2023 Notice (6) CM-STATUS message sent. Event Type Code: 20; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:34:02 2023 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:32:14 2023 Notice (6) CM-STATUS message sent. Event Type Code: 22; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:29:15 2023 Notice (6) CM-STATUS message sent. Event Type Code: 20; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:29:02 2023 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:28:54 2023 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:11:58 2023 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:11:46 2023 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:11:41 2023 Notice (6) TLV-11 - unrecognized OID;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:04:34 2023 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:04:30 2023 Notice (6) CM-STATUS message sent. Event Type Code: 22; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:04:27 2023 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:04:03 2023 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:04:01 2023 Notice (6) CM-STATUS message sent. Event Type Code: 20; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 16:04:00 2023 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 15:51:39 2023 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 15:51:27 2023 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 15:51:22 2023 Notice (6) TLV-11 - unrecognized OID;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 15:48:05 2023 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1; Sun Jun 25 15:48:00 2023 Notice (6) TLV-11 - unrecognized OID;CM-MAC=34:98:b5:ce:cf:99;CMTS-MAC=00:01:5c:a8:bc:49;CM-QOS=1.1;CM-VER=3.1;
