onebads2k
Jan 24, 2021Aspirant
cm1200 & XR500 half wifi speeds
So just moved to a new house, and I also got a new modem, a CM1200 for gigbit speeds. ISP is 1200mbps, and I was troubleshooting with them, but they said they are sending those speeds, so they t...
onebads2k
Direct connected to my xbox only sees 550-600 as well?
Jan 24, 2021Guru - Experienced User
Do you have a wired PC or laptop to test with. I've never been confident in MS speed tests on game consoles. YOu can't set a different test site on consoles, where PC or laptop with Speed test app you can.
