After turning off my modem for a few ho and powering it back on after a lengthy period, my upstream light is now flashing green.
| Startup Procedure |
| Procedure | Status | Comment | | Acquire Downstream Channel | 765000000 Hz | Locked | | Connectivity State | OK | Operational | | Boot State | OK | Operational | | Security | Enabled | BPI+ | | IP Provisioning Mode | Honor MDD | honorMdd(4) |
| Downstream Bonded Channels (Partial Service) |
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables | | 1 | Locked | QAM256 | 31 | 765000000 Hz | 9.4 dBmV | 41.5 dB | 0 | 0 | | 2 | Locked | QAM256 | 1 | 585000000 Hz | 8 dBmV | 42 dB | 0 | 0 | | 3 | Locked | QAM256 | 2 | 591000000 Hz | 8 dBmV | 42.1 dB | 0 | 0 | | 4 | Locked | QAM256 | 3 | 597000000 Hz | 8.1 dBmV | 37.6 dB | 0 | 0 | | 5 | Locked | QAM256 | 4 | 603000000 Hz | 8.1 dBmV | 40.8 dB | 0 | 0 | | 6 | Locked | QAM256 | 5 | 609000000 Hz | 8.1 dBmV | 42.2 dB | 0 | 0 | | 7 | Locked | QAM256 | 6 | 615000000 Hz | 8 dBmV | 42.1 dB | 0 | 0 | | 8 | Locked | QAM256 | 7 | 621000000 Hz | 8.1 dBmV | 42.1 dB | 0 | 0 | | 9 | Locked | QAM256 | 8 | 627000000 Hz | 8 dBmV | 42 dB | 0 | 0 | | 10 | Locked | QAM256 | 9 | 633000000 Hz | 7.5 dBmV | 41.7 dB | 0 | 0 | | 11 | Locked | QAM256 | 10 | 639000000 Hz | 5.8 dBmV | 41 dB | 0 | 0 | | 12 | Locked | QAM256 | 11 | 645000000 Hz | 5.9 dBmV | 41.1 dB | 0 | 0 | | 13 | Locked | QAM256 | 12 | 651000000 Hz | 6.9 dBmV | 41.4 dB | 0 | 0 | | 14 | Locked | QAM256 | 13 | 657000000 Hz | 7.8 dBmV | 41.6 dB | 0 | 0 | | 15 | Locked | QAM256 | 14 | 663000000 Hz | 8.5 dBmV | 41.7 dB | 0 | 0 | | 16 | Locked | QAM256 | 15 | 669000000 Hz | 8.9 dBmV | 41.8 dB | 0 | 0 | | 17 | Locked | QAM256 | 16 | 675000000 Hz | 9.5 dBmV | 41.5 dB | 0 | 0 | | 18 | Locked | QAM256 | 17 | 681000000 Hz | 9.2 dBmV | 41.9 dB | 0 | 0 | | 19 | Locked | QAM256 | 18 | 687000000 Hz | 8.3 dBmV | 41.6 dB | 0 | 0 | | 20 | Locked | QAM256 | 19 | 693000000 Hz | 8.7 dBmV | 41.6 dB | 0 | 0 | | 21 | Locked | QAM256 | 20 | 699000000 Hz | 8.9 dBmV | 41.8 dB | 0 | 0 | | 22 | Locked | QAM256 | 21 | 705000000 Hz | 8.9 dBmV | 41.7 dB | 0 | 0 | | 23 | Locked | QAM256 | 22 | 711000000 Hz | 8.3 dBmV | 41.5 dB | 0 | 0 | | 24 | Locked | QAM256 | 23 | 717000000 Hz | 7.6 dBmV | 41.3 dB | 0 | 0 | | 25 | Locked | QAM256 | 24 | 723000000 Hz | 7.5 dBmV | 41.2 dB | 0 | 0 | | 26 | Locked | QAM256 | 25 | 729000000 Hz | 8.4 dBmV | 41.3 dB | 0 | 0 | | 27 | Locked | QAM256 | 26 | 735000000 Hz | 9.1 dBmV | 40.7 dB | 0 | 0 | | 28 | Locked | QAM256 | 27 | 741000000 Hz | 9.6 dBmV | 40.1 dB | 0 | 0 | | 29 | Locked | QAM256 | 28 | 747000000 Hz | 10 dBmV | 39.8 dB | 0 | 0 | | 30 | Locked | QAM256 | 29 | 753000000 Hz | 10.3 dBmV | 39.1 dB | 0 | 0 | | 31 | Locked | QAM256 | 30 | 759000000 Hz | 10.1 dBmV | 41.7 dB | 0 | 0 | | 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| Upstream Bonded Channels (Partial Service) |
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power | | 1 | Locked | ATDMA | 1 | 5120 Ksym/sec | 17400000 Hz | 49.5 dBmV | | 2 | Not Locked | Unknown | 2 | 0 Ksym/sec | 17400000 Hz | 0.0 dBmV | | 3 | Not Locked | Unknown | 3 | 0 Ksym/sec | 23800000 Hz | 0.0 dBmV | | 4 | Not Locked | Unknown | 4 | 0 Ksym/sec | 36600000 Hz | 0.0 dBmV | | 5 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 6 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 7 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 8 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| Downstream OFDM Channels |
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords | | 1 | Locked | 0 ,1 | 159 | 300000000 Hz | 6.0 dBmV | 42.1 dB | 1108 ~ 2987 | 32338981 | 843539 | 0 | | 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
| Upstream OFDMA Channels |
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | | 1 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | | 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV |
As you can see, I do have a locked bonded channel. My upstream power is less than last time, which I would prefer. But my internet drops if I upload something. |
| Time | Priority | Description | | Sun May 10 00:31:15 2020 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:3d:f1:08;CMTS-MAC=00:6c:bc:b8:34:ea;CM-QOS=1.1;CM-VER=3.1; | | Sun May 10 00:31:15 2020 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3d:f1:08;CMTS-MAC=00:6c:bc:b8:34:ea;CM-QOS=1.1;CM-VER=3.1; | | Sun May 10 00:31:06 2020 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:3d:f1:08;CMTS-MAC=00:6c:bc:b8:34:ea;CM-QOS=1.1;CM-VER=3.1; | | Sun May 10 00:30:35 2020 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:3d:f1:08;CMTS-MAC=00:6c:bc:b8:34:ea;CM-QOS=1.1;CM-VER=3.1; |
