spritesaga
May 09, 2020Aspirant
CM1200 Amber Upstream Light and Occasionally Blinking Downstream Light
Hey all, I have a brand new Netgear CM1200 modem and Netgear R7000 router. My ISP is Spectrum. On my first day, my upstream light was blinking, but after restarting my modem, now I have a con...
vkdelta
Jul 26, 2020NETGEAR Employee Retired
last screenshot showed it is partial service.
Need new screenshot for connection table + event Logs
spritesaga
Jul 27, 2020Aspirant
Here you go. Although it should be noted I'm not having any major issues right now.
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
Startup Procedure
| Procedure | Status | Comment |
| Acquire Downstream Channel | 300000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enabled | BPI+ |
| IP Provisioning Mode | Honor MDD | honorMdd(4) |
Downstream Bonded Channels (Partial Service)
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |
| 1 | Locked | QAM256 | 1 | 585000000 Hz | 9.6 dBmV | 42.4 dB | 0 | 0 |
| 2 | Locked | QAM256 | 2 | 591000000 Hz | 9.7 dBmV | 42.5 dB | 0 | 0 |
| 3 | Locked | QAM256 | 3 | 597000000 Hz | 9.8 dBmV | 42.4 dB | 0 | 0 |
| 4 | Locked | QAM256 | 4 | 603000000 Hz | 9.8 dBmV | 42.4 dB | 0 | 0 |
| 5 | Locked | QAM256 | 5 | 609000000 Hz | 9.8 dBmV | 42.4 dB | 0 | 0 |
| 6 | Locked | QAM256 | 6 | 615000000 Hz | 9.8 dBmV | 42.4 dB | 0 | 0 |
| 7 | Locked | QAM256 | 7 | 621000000 Hz | 9.8 dBmV | 42.3 dB | 0 | 0 |
| 8 | Locked | QAM256 | 8 | 627000000 Hz | 9.7 dBmV | 42.3 dB | 0 | 0 |
| 9 | Locked | QAM256 | 9 | 633000000 Hz | 9.2 dBmV | 42 dB | 0 | 0 |
| 10 | Locked | QAM256 | 10 | 639000000 Hz | 7.7 dBmV | 41.5 dB | 0 | 0 |
| 11 | Locked | QAM256 | 11 | 645000000 Hz | 7.5 dBmV | 41.4 dB | 0 | 0 |
| 12 | Locked | QAM256 | 12 | 651000000 Hz | 8.4 dBmV | 41.7 dB | 0 | 0 |
| 13 | Locked | QAM256 | 13 | 657000000 Hz | 9 dBmV | 41.8 dB | 0 | 0 |
| 14 | Locked | QAM256 | 14 | 663000000 Hz | 9.5 dBmV | 42 dB | 0 | 0 |
| 15 | Locked | QAM256 | 15 | 669000000 Hz | 9.7 dBmV | 41.9 dB | 0 | 0 |
| 16 | Locked | QAM256 | 16 | 675000000 Hz | 10.1 dBmV | 41.5 dB | 0 | 0 |
| 17 | Locked | QAM256 | 17 | 681000000 Hz | 9.9 dBmV | 42 dB | 0 | 0 |
| 18 | Locked | QAM256 | 18 | 687000000 Hz | 9.3 dBmV | 41.8 dB | 0 | 0 |
| 19 | Locked | QAM256 | 19 | 693000000 Hz | 9.5 dBmV | 41.8 dB | 0 | 0 |
| 20 | Locked | QAM256 | 20 | 699000000 Hz | 9.8 dBmV | 41.8 dB | 0 | 0 |
| 21 | Locked | QAM256 | 21 | 705000000 Hz | 9.6 dBmV | 41.8 dB | 0 | 0 |
| 22 | Locked | QAM256 | 22 | 711000000 Hz | 9.1 dBmV | 41.6 dB | 0 | 0 |
| 23 | Locked | QAM256 | 23 | 717000000 Hz | 8.5 dBmV | 41.4 dB | 0 | 0 |
| 24 | Locked | QAM256 | 24 | 723000000 Hz | 8.5 dBmV | 41.2 dB | 0 | 0 |
| 25 | Locked | QAM256 | 25 | 729000000 Hz | 9.6 dBmV | 41.6 dB | 0 | 0 |
| 26 | Locked | QAM256 | 26 | 735000000 Hz | 10.2 dBmV | 41.8 dB | 0 | 0 |
| 27 | Locked | QAM256 | 27 | 741000000 Hz | 10.8 dBmV | 41.9 dB | 0 | 0 |
| 28 | Locked | QAM256 | 28 | 747000000 Hz | 11.2 dBmV | 42 dB | 0 | 0 |
| 29 | Locked | QAM256 | 29 | 753000000 Hz | 11.5 dBmV | 42.1 dB | 0 | 0 |
| 30 | Locked | QAM256 | 30 | 759000000 Hz | 11.3 dBmV | 42.1 dB | 0 | 0 |
| 31 | Locked | QAM256 | 31 | 765000000 Hz | 10.4 dBmV | 41.9 dB | 0 | 0 |
| 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
Upstream Bonded Channels (Partial Service)
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 1 | 5120 Ksym/sec | 17400000 Hz | 43.3 dBmV |
| 2 | Not Locked | Unknown | 2 | 0 Ksym/sec | 17400000 Hz | 0.0 dBmV |
| 3 | Not Locked | Unknown | 3 | 0 Ksym/sec | 23800000 Hz | 0.0 dBmV |
| 4 | Not Locked | Unknown | 4 | 0 Ksym/sec | 36600000 Hz | 0.0 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
Downstream OFDM Channels
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0 ,1 ,2 | 159 | 300000000 Hz | 7.8 dBmV | 42.5 dB | 1108 ~ 2987 | 13144213389 | 1129881049 | 0 |
| 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
Upstream OFDMA Channels
| 1 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV |
- vkdeltaJul 30, 2020NETGEAR Employee Retired
It is still partial service though.
- spritesagaJul 30, 2020Aspirant
Correct, it is still partial service. But it works :)
- kryptoknightJul 31, 2020Tutor
So I went ahead with the purchase of the CM1200 (again) to replace the Spectrum stock modem (citron). First day was was normal - CM1200 hooked up to the RAX200. Recently switched to the gigabit plan with Spectrum. Speeds tested were good with multiple tests - wasn't really expecting to achieve the full 1gbps download speed but did get substantial improvement over the stock modem. Approximately 24 hours later, the upload light starting blinking on the CM1200. Checked cable connection status before and after light blinking and they are the same. No loss of connection and degradation in speeds for both download and upload. So I seem to be in the same situation - upload light blinking green on the cm1200 but yet no connection issues. Just wondering why it's blinking though?? I got 3 upstream bonded channels locked and 1 upstream ofdm channel locked. See attached for screenshots. of the connected channels. I have not rebooted the modem yet since the blinking of the light. Will see what happens on its own in a few days. Any Netgear folks reading through these community entries?? Are you looking into this??
- FURRYe38Aug 01, 2020Guru - Experienced User
Do does the Hitron modem do the same thing with the blinking US led?
kryptoknight wrote:So I went ahead with the purchase of the CM1200 (again) to replace the Spectrum stock modem (citron). First day was was normal - CM1200 hooked up to the RAX200. Recently switched to the gigabit plan with Spectrum. Speeds tested were good with multiple tests - wasn't really expecting to achieve the full 1gbps download speed but did get substantial improvement over the stock modem. Approximately 24 hours later, the upload light starting blinking on the CM1200. Checked cable connection status before and after light blinking and they are the same. No loss of connection and degradation in speeds for both download and upload. So I seem to be in the same situation - upload light blinking green on the cm1200 but yet no connection issues. Just wondering why it's blinking though?? I got 3 upstream bonded channels locked and 1 upstream ofdm channel locked. See attached for screenshots. of the connected channels. I have not rebooted the modem yet since the blinking of the light. Will see what happens on its own in a few days. Any Netgear folks reading through these community entries?? Are you looking into this??
- kryptoknightAug 01, 2020TutorNope.
Something to keep in contact with NG with then.
